buying Shed -Floor dilemma
21 Nov 2005
I'm currently looking for a 12x10 shed, I found a few made from redwood? not tanalised or npthing, heavy duty 3x2 framework, roof joists but the floor are just plain planks.
I want it to last , and will have my motorbike in their aswell so want it be sufficient while still on a budget- rented house.
these are some examples, are the thickness of the T&G/ boards/floors etc ok
13mm t&g
25mm floor planks
http://www.ebay.co.uk/itm/GARDEN-SH...872?pt=LH_DefaultDomain_3&hash=item4abc0671d8
It's going on a sound concrete base- raised.
line the main floor area with 12mm ply
then if it gets damaged you replace
25mm flooring is likely to be 21mm as planed timber is quoted by the pre worked stock size
also 3x2" cls is 1.5x2.5" 38x63mm
Was going to line it, and have a extra protection where the bike will be.
Is that shed specs ok you think structurally.
Thanks for your help.
same size as my shed but i built my own :D :D
http://s21.photobucket.com/albums/b270/bigall2005/?action=view&current=e1e47346.pbw
dosnt look bad they say sawn floor well that refers to the sawn timber size so floorboards will be worked size[21mm]
the shiplap [cladding]will be 13mm
so in answer to your question 19mm cladding is what i have and is solid as a rock at 2ft centers
i have 3x2"actual so around 60% stronger than cls but would be happy with cls as i tend to over engineer
looks a good shed as you expect them to give better value for money as they will buy the wood by the metric ton and get it for 1/3 what we pay :D
If the base hasn't been cast yet you should perhaps give consideration to some sort of anchor for a bike chain, or other security measure.
Thanks Big-All for your advice, and that's some workshop you got there.
I think I will settle on this type of shed maybe go a couple ft bigger if I can afford it. I just have to sort the base out now, materials are so expensive these days :eek:
@HH1 good tip will look into that.
