I have recently replaced a 1 gang two way switch with a 1 gang two way dimmer rated at 850 watts suitable for use with low voltage lights
connected to this are 9 50watt low voltage fittings each with their own 60 watt low voltage transformer
since I have fitted this I have noticed that the 6amp MCB on the dist board buzzs when the lights are turned on
the lamps all appear to be working correctly and do not flash etc when dimmed to a low level
the dimmer is not getting too hot and is not buzzing itself (it is a electronic type rather than a wire wound type)
I would like to know if there is anything to worry about, or if this is normal?
thanks.
thanks.
