buzzing shower
24 Oct 2007
Staffordshire
Hi, we have a Thermostatic shower (this one) thats started to buzz.
If we turn the HW up a bit it normally goes away.
What causes this and how to fix?
At a guess is it because the water pressure is too high or not balanced?
Cheers
Dan
This is either a piece of debris, or a problem with the cartridge.
There are usually filters on the inlets to this type of valve. If you isolate the water and remove the valve from the wall then you'll see. Check that they are unobstructed and intact. If a filter is broken then something may have become lodged inside the valve.
You may also/instead see check valves, and itty bits of debris can easily get lodged on those. The noise might even be a sticking check valve.
