Buzzing Shower
15 Jul 2009
Norfolk
I have a Triton mixer shower, web page https://www.tritonshowers.co.uk/mixer-showers/mersey-dual-control-mixer-shower.html which buzzes when you first switch it on. It only does it for a few seconds while it gets up to the set temperature but is really annoying. It has only started doing it recently and seems to be getting worse.
When you switch it on and it starts buzzing, if you turn the temperature knob clockwise until the buzzing stops then turn it back to the temperature you want, that seems to 'cure' it until the next time.
Any ideas what is causing this?
The shower is around 10 years old so definitely out of warranty :eek:
Is there a spare 'part' which can be replaced or does the whole lot need to be replaced?
I went to a flat with a water noise problem on Monday.
They said there was a noise coming sometimes from the shower head.
Discovered there was a small impeller like wheel inside that was meant to turn all the time but was only occasionally doing so!
