I have an old vented boiler sited in the loft ,been running for 28 years now, and I want to change it. because it's in the loft there is not much height for the expansion tank and sometimes it gets a bit hot and tends to blow steam for a while.
so my question is, can I use a combi boiler ,which I believe is fed from mains under pressure and will not require a header tank so I could still locate it in the loft and as I have just fitted a new hot water tank in the airing cupboard i would not want to use the hot domestic water supply from the combi.
would it be OK to just use the combi boiler for hot radiator water and leave the other section un -connected or would it cause the heater coils inside to overheat ??
