We are setting out the pipes for the C/H, and due to the size and construction of the house we are ending up with a somewhat "star" system, for example there is a central run which then gives off smaller bore into 1 or 2 radiators that happen to be close together, then the central run continues to some other part of the house where there is another branch etc. Some branches also go upstairs to feed a couple of radiators each.
I would like to ask, as the runs are long, I have some straight long runs that are sloping downwards a bit. Is that a recipe for disaster (air trapped) ?
Secondly, is it OK to go up 1.5m and then come down into a radiator? The plumber said this is very bad because air will get trapped in that section, but can't I just have auto-air-bleed valves at the highest points? The reason I want to go up 1.5m and then down into a radiator is so that I can hide the pipes better. Otherwise I would have to run them on or in the floor which is a major pain.
