My house was built around 1979 and has a central heating system with microbore pipe work, 5 rads upstairs & 4 downstairs. We changed the original boiler and open system to a Baxi Duotec HE 28 condensing combi boiler a number of years ago when we moved here. We are struggling to heat the house fully, as in the rads don't get hot enough. The heating engineer who services the boiler for me once a year has told me that the boiler is fine and the problem is due to the microbore pipes. The boiler short cycles when the heating is on. Over the last couple of years I have had the most problematic rads off and given them a good flushing outside, I have run Sentinel X400 through the system and then flushed the system and each rad individually using the filling loop and system drain cock, then topped up and added X100 inhibitor. If I isolate all the rads except one, that one open rad will get plenty hot enough, so I know each rad and it's pipework works fine, but with all rads open they get warm but not very hot. I have done a general balancing to prevent the upstairs rads getting preference on the heat so they all warm up, but don't get hot enough. The engineer who does my service said he did not recommend a powerflush on the system as it might cause further problems and the system maybe clean enough now to not warrant it anyway.
Has anybody got any other tips or advice for me to try to get warm?
Thanks for reading.
Thanks for reading.
