Hi All
Yesterday, my wife switched on the ceiling lights in the lounge, but the light bulb blew and tripped out the circuit breaker on the main fuse panel. Bulb has been replaced and the circuit breaker reset, and lights now work fine.
However, since then the C&K alarm has failed to work. The "mains" light is no longer lit on the keypad, but the keys do emit a beep and light up when pressed.
I have checked the 5A spur fuse next to the metal panel, but this appears to be fine.
Is there anything I can check inside the panel box to see why the keypad is reporting no mains?
I also believe that it still running on the original backup battery. Will I need to replace this too?
Any help would be appreciated.
Cheers
Carrera
Cheers
Carrera
