Hello,
Our old 9.5 kw Triton shower has died beyond repair and we were thinking about replacing it with a 9.5 kw Aqualisa Aquastyle.
The shower cable is 6mm and runs openly through the ventilated roof space at the edge of our dormer bungalow and then up the un-insulated internal wall to the shower. As far as we can see from the Aqualisa installation guide 6mm cable is OK as long as it runs in open and venitilated spaces or un-insulated walls which ours does. However, we have been advised that nonetheless we really should change to 10mm cable or drop down to a 8.5 kw shower but we suspect that this advice is being over cautious as the current shower is 9.5 KW with no sign of any problems with the cable, our house wiring was inspected and certified a few months ago.
We will be buying the shower but it will be fittted by our local plumber, are we OK to go ahead and buy the 9.5 kw version to replace our existing 9.5 kw shower or should we go down the cautious route and drop to an 8.5 kw shower and risk a rather more poor shower performance?
Thank you.
Thank you.
