Im moving a light fitting outside, 500W flood light, standard unit. Its being moved higher up so i need to re-run the cable to the light as the old cable will be too short.
Currently, the cable to the light is flat grey T&E as used internally under the floor for the lighting ring.
What cable should i use? Light is 500W approx. 3A, so was thinking of 6A round flex:
http://www.tlc-direct.co.uk/Products/CA0dot75F3Bslash50.html
The cable length will be about 13m if that makes any difference?
