Cable for light in shed
Status
Not open for further replies.
4 Jul 2008
Staffordshire
Was planning on buying a bit of 1.5mm flat grey cable to run from a 13A Fused switched Spur (changed the fuse for 3A)
Its just got to power one 10w Led Lamp in the shed. Is this the correct cable? The light doesn't appear to have an earth connection on it so do I just run 2 core cable from the switch to the light?
No on all accounts. Flat twin and earth is not suitable for outside. You cannot not use 2 core cable as someone may change the light. 1.5mm cable is oversized for lighting, 1.0mm is the correct size.
I initially mis-read the OP in the same way winston. After reading his other thread, this is not the supply to the shed, he has already done SWA, this is only within the shed.
So, OP, yes, you can use twin and earth. But as winston says, you can't use 2 core cable.
Yes correct its within the shed. Is the earth wire supposed to be earthed to the body of the lamp then or is it snipped off and not used? I ask as there isn't any where to fix it to that I can see.
Thanks for correcting me on the size of cable and it's within the shed. Should have made it clearer.
If the lamp is plastic or double insulated(has a square in a square symbol), then you don't connect the earth, but it must be spare for future use, so don't snip it off short. Put some green/yellow sleeving on it, a single connector block on the end and park it safely inside with the other terminals.
Great, thanks for your help it's much appreciated.
It's one of Winston's obsessions which (sadly) he regularly inflicts upon us.
1.5mm² is more versatile than 1mm², harder to break when tightening terminal screws and will fit the terminals of switches etc with no problems at all.
Despite anything he might want you to believe, you would not be wrong to buy it.
Give it a rest, Winston - you are tedious beyond belief.
And even when you try to quote a thread which you think supports your obsession you fail to notice that it contains posts which also make the point that 1.5mm² is more versatile than 1mm² and more robust.
Not at all. Just trying to help the OP from wasting money unnecessarily.
Not an obsession. Virtually all the posts said 1.5 mm was unnecessary. Except perhaps for very long feeds.
As usual you are arguing for the sake of it when you are clearly wrong.
How much hands on experience do you have of installing electrical systems ?. As one poster in the IET forum said sometimes it is cheaper to use 1.5mm² due to the cost of purchasing a small quantity of 1 mm² ( did you miss it ? ).
Status
