Hi i have a all electric house, heaters, cooker, hot water cylinder, showers etc. if all apliances are turned on the thick black cable to the 100amp fuse gets warm to touch. is this normal / safe?
And even house wiring cables are expected to get up to 70°C, which would be hot enough to burn, or if not at least make you break contact quickly whilst saying rude words.
Cover something that hot with just a few mm of PVC and it will feel warm.
I have no clue about electrics so this is a very uninformed comment, but we had problems with the supply to our house. An electrician who came to investigate pointed out that the incoming cable, and the main fuses, were very hot. (This was not the problem he came to investigate but another symptom). The fault was diagnosed as the incoming cable being too small and also the wrong specification cable. This cable was changed and now everything is cold.
An all-electric house will use a lot (what exactly do you have?) so the 2 phase suggestion could well have been valid. You can get an energy meter for about £30 which you clip on to one of the tails and it has a remote display which tells you how much you are using. If you don't already have a 100A fuse in the service head (there is no way for you to check this for certain without calling out the DNO) then you should definitely see about getting the supply upgraded.
