Hows this for a cable joint?
It was a 2.5mm rubber insulated joined to a new set of 6mm singles supplying an oven.
The 2 lots of 10mm earth actually went as the main equipotential bonding down to the water and the gas and was joined to an old earth wire that they used to loop round old houses and tap everything into.
Guess you could say it failed the test
