His value to the thread topic has been zero
Just a quickie.
Bearing in mind that that FCU is for the lights, that is the best way to do it you who won't be told.I am doing is just answering the posts - no more. Some responses are odd for sure. Please show me where I have botched anything - one of your professionals was advocating a 4mm spur cable off a 2.5mm ring with socket and FCU off it. Read it, it is there, I never made it up. Look at some of the replies - these are professionals? My oh my!
I put the first post in a simple way to avoid this, but this being this forum, this is what you get. A lot of one liners as well, like "you don't know what you are doing" and "you are wrong" and "you are botcher", etc, with nothing explaining where I was wrong or what the preferred solution would be in their eyes (very short on that point).Only in relationship to the life time of the universe has this post been a quickie
Yes, I will not be told, as it is not the correct solution. Why? because FCUs are hard to press switches which are not good for young and old hands. FCUs for light switches is not a good idea - a last resort.Bearing in mind that that FCU is for the lights, that is the best way to do it you who won't be told.
Interesting. That counters Sunray who says only 16A mcb on the spur cable.Either you select an over-current device for the rating of the cable or select the cable for the rating of the 32A MCB.
I fully understand that and you know that. The 4mm cable, I did say was electrically sound, just not the way it is done.A mistake you keep making is not seeming to recognise that a 2.5mm² ring has TWO cables, i.e. it is a 5mm² circuit.
Initially I only asked one, then the thread went onto the second point of the ideal method of protection of a small outbuilding or garage CU spurred off a ring - a common situation. So two in all. I did give an example of a solution which I did by splitting the ring into two radials, but that is not always feasible as a ring may have to stay in place. So far you say one thing, and Sunray says another.There are so many options in what you are asking about that it is impossible to answer without knowing what you are thinking, let alone a yes/no.
It offers fusing and isolation, you may of course have an ordinary switch as well.Yes, I will not be told, as it is not the correct solution. Why? because FCUs are hard to press switches which are not good for young and old hands. FCUs for light switches is not a good idea - a last resort.
I can't be bothered to reread everything. To what was it referring.Interesting. That counters Sunray who says only 16A mcb on the spur cable.
How do you know? If it is electrically sound then there can be no objection.I fully understand that and you know that. The 4mm cable, I did say was electrically sound, just not the way it is done.
You did - a No and Yes would have been strictly correct but not knowing what you were thinking would have been irresponsible.Initially I only asked one, then the thread went onto the second point of the ideal method of protection of a small outbuilding or garage CU spurred off a ring. So two in all.
Whether feasible or not, it is a stupid solution and no one would have known that was the sort of thing you were thinking.I did give an example of a solution which I did by splitting the ring into two radials, but that is not always feasible as a ring may have to stay in place.
