I intend replacing my old tv cable with good quality stuff. I have been on the roof and had an inspection. 2 cables come off the aerial down the chimney stack and then off to the right and left down the roof about three tiles down and into the loft from both sides.
so :-
1 moving the cable about was tricky. it was stuck under the tiles which is to be expected i suppose. Will I simply need to wedge the tile upwards to move this about freely? No need to remove the tile?
2 Once I have the new cable into the loft I intend taking it out of the soffit at the back of the house down the wall to the point where it should enter the house into my front room. i presume i can just drill the soffit? and sealent it afterwards?
3 I can get on the roof from the apex from an an extension which has a flat roof. Is it ok to tread very very carefully across the three feet or so to the chimney stack on the oval tiles that go across the point or top of the roof? These are larger than the regular tiles that go down the roof
so :-
