I am fitting out what used to be a scullery/laundry room. Walls are mix of solid brick and solid flint. The two external walls (brick) will be battened, filled with polystyrene sheet and plaster-boarded. Another is rendered on top of the old outside wall of flint and will be skimmed and painted the other is an internal solid brick wall which will be boarded (dabbed) and skimmed.
I have power coming into the room at ceiling level and need a generous number (10 x 2 gang) sockets at near floor level. It is a solid floor.
The temptation is to take feed down to first socket and then along at floor or just above skirting level around and through all other sockets before rising back to feed and completing ring. Is this acceptable and what protection is required - or should I take a two cable in and out feed to each as I believe that anything else would create too many spurs.
