Hello again,
I have a query about a proposed cable run through our kitchen.
A new electric oven (3.8kW) was installed by the previous owner, the feed for which was surface mounted in trunking back to the CU by the front door. To reduce damage and the need to replaster we're not bothered about keeping the trunking in the kitchen, although we can easily remove it from the hall and reroute through the ceiling. So, can we run the ring for the sockets through the trunking, which runs down behind the worktop, and pop it up to the sockets above the worktop as required. The cable would be buried where it comes up for the sockets. This means I can more easily work around present tiling and finishing, only removing and replacing a few tiles.
Effectively what I'm trying to avoid is chasing every plug down from the ceiling.
Is this something that's more easily explained with a photo or does it makes sense?
Thanks.
Thanks.
