I'm about to run cable around a new extension. The room is largely glass walled, so no cable runs down them! The floor has a dpc - concrete - celotex - screed - tile floor construction. I plan to run 2.5mm cable around the edge of the room looping up up to the sockets.
Questions are
a) should the cable be in conduit, if so what type? It will be beneath 65mm screed on top of which will be tiles, so it should be well out of harms way. Celotex is foil faced.
b) are the cables best run above or beneath the Celotex?
For the lighiting there is no ceiling void so with glass walls as well my choices are limited. I plan to run cabling along the top of the ventilated sofit board (behind the external facia) as this is currently accessible and provides a neat solution to getting the lighting runs in. Again - should this be in trunking or conduit or are clips adequate??
Cheers
Questions are
Cheers
