Eh Up!
Ok brickie requires advice.
Putting approx 12 mini downlights in ceiling using 20w G4 capsule bulbs.
Cut out is only 25mm diameter so access to tranny is not possible after fitting. I am putting this circuit on 1.5mm T&E and hope for it to be dimmable.
Problem is access to trannys (no jokes please) so it would make sense to place them in one location but i believe this gives rise to problems ie voltage drop.
What size cable could i use, if its feasable with the correct trannys, to connect lamp to tranny max distance 4 metres apart.
If i use bigger cable between tranny and lamp will this affect the 1.5mm T&E for the normal circuit ie from switch to tranny.
Is this possible?
Cheers
Stanna
Is this possible?
Cheers
Stanna
