Just bought some new powered PA speakers and need to extend the mains cable to each a little. I am a bit confused on the cable size to use though. The plug supplied with each speaker has a plug fitted with a 13A fuse and the attached cable is 3 core 0.75mm2. I went to Maplin and bought a length of 3 core 0.75mm cable. However the ticket they have on the cable reel called the cable "6A 3 core 0.75mm2 mains cable". Is this cable suitable? it looks I dentical to the cable provided with the speakers but why would they fit a 13A fuse if the cable only takes 6A? I don't believe the speakers run at anywhere near 13A.
Many thanks,
Josh
Many thanks,
Josh
