dadavid6 said:so what cable size do you recomend i should use?- if it was 32 amps, what size cable should i use? for also 95 meters
thank you!
now you're just looking to cut corners to reduce cost.dadavid6 said:so what cable size do you recomend i should use?- if it was 32 amps, what size cable should i use? for also 95 meters
thank you!
