Cabling from downstairs, upstairs
17 Jul 2018
So I’m in a relatively new build house, built 2018
Looking to run some network cable from the downstairs hub upstairs to another room.
Be interested in thoughts on approach
Option 1 - Through the ceiling with some vertical mini trunking hiding the cabling as far as possible...
Option 2 - Attempting to fish from upstairs, downstairs, behind the plasterboard...
Option 3 - Out through the external wall, up, and in through the upstairs external wall
Would appreciate any pro’s, con’s, do’s, don’t, recommend kit etc
How do central heating pipes get from the ground floor to upper floor, might you be able to share that route?
If the walls have an empty cavity, could you use that? Into cavity on upper floor, then fish out through wall on ground floor.
Fishing through plasterboard, you would have to find the horizontal batons, make a hole, out then back in again. Finally plaster up the holes in the plasterboard.
Sadly heating pipes and wrong side of the room entirely.
Forgive me but when you say the walls having an empty cavity, isn’t it a certainty I’ll hit however made horizontal batons on the way up and down?
Cavity in an outside wall, unless they are insulated. It is a certainty that you will find batons in a stud wall, which fill prevent you from fishing all the way. .
I would use the cavity wall and as a last resort take it outside and back in again
Trucking looks unsightly and anything else means making mess
Or power link adapters
