What is a caravan? Of interest only not trying to have a go at Lectrician as it did make me go and research what a caravan is and I have make some mistakes:-
A trailer leisure accommodation vehicle, used for touring, designed to meet the requirements for the construction and use of road vehicles.
Not for habitation purposes.
To be for habitation it must have an adequate piped supply of wholesome water a suitably located water closet for the exclusive use of the occupants for the exclusive use of the occupants (if any), a suitably located fixed bath or shower and a wash hand basin each of which is provided with a satisfactory supply of hot and cold water and it has an effective system for the draining of foul water and surface water. This was taken from Portsmouth City Council web site but I would suspect the same definition would apply nation wide.
So a touring caravan is not for habitation unless water and drains are connected.
MOBILE OR TRANSPORTABLE UNITS however do have some common rules with caravans so also one must look at Section 717 and the Mobile Home it seems would come under that section. So 717.52.1 Flexible cables (for connecting the unit to the supply) in accordance with H07RN-F (BS 7919), or cables of equivalent design, having a minimum cross-sectional area of 2.5 mm² copper shall be used. The flexible cable shall enter the unit by an insulating inlet in such a way as to minimize the possibility of any insulation damage or fault which might energize the exposed-conductive-parts of the unit. Will apply and guess what that is even more restrictive than the one for caravans.
I realise 521.9.3 A flexible cable or flexible cord shall be used for fixed wiring only where the relevant provisions of the Regulations are met. But as yet I have not worked out what the relevant provisions are may be you would like to enlighten me.
The BS 7671:2008 regulations are complex and I would not profess to know them all so in the main look at what would make sense and any portable building will flex and so wiring it in cable that will also flex makes sense.
I have made mistakes and I will admit it when I have but here I think I was right to advise on flex although if you can quote any regulation which says otherwise I will take notice.
Eric
