More questions Im afraid.
Reading one of the posts here that said not to have cabling in cavity walls which are insulated and following on from this I would like to check a few things with you guys.
Currently I have the cables going to my light switches running in the cavity wall, only from the cieling to the lightswitch, Recently found we have cavity wall insulation and was wondering if these cables should be moved?
If the cables are to be put in the wall I understand that they should be placed in conduit to allow for the cable to be easilyt replaced and to allow a little protection for the cable, However I have heard several mentions of armoured cableing and metal conduit, what are the reasons for using these? or should you never use plastic conduit and standard cabling?
along the same lines I heard mention of using single core cabling, is this for specific purposes or all purposes.
Am I right in assuming that any cables put in the wall should run in a strainght line up from the sockets/switches?
Now I know some of these may seem simple to some of you guys but I just wanted to make sure i understand whats the best way to do these things.
Thanks for your time and look forward to having these things a little cleareer in my mind
