can someone pls help......i have just installed underfloor heating in our newly built kitchen using 22mm copper pipe. The subfloor was membraned and properly insulated using 100mm jablite and concreted and the pipe work was covered with denzel tape and then the floor screeded and tiled. The under floor heating in this area works just fine. i am this summer thinking of carrying on this underfloor heating link into the adjacent through lounge. my question is can my boiler handle all this pipework?..... as i have no way of calculating the btu value of just pipes covering my floors!!...... i have a worcester bosch 40cdi condensing boiler supplying the houses needs. my lounge is approximately 27ft x 16ft.
the kitchen was piped only in the usable walking areas and not underneath the units!.... pls help. i dont wonna install any plastic poly tube. many thanx in advance.
