Agreed.Plenty of online calculators, although they tend to over egg the pudding:
The heating load is not dependent on the water temperature; the size of rad is.4 bed detached with assumed insulation up to scratch... total load - 9255W at mean flow of 55 and outside temp of -3.
Yes!You think?
The physical size of radiator will vary with water temperature because the output varies with temperature, but the heat requirement will not change.I was doing my calcs as part of a complete design. My rads are being sized as I described.
