I am planning to remove a load bearing wall (single brick wide) between kitchen and dining room. It supports 8"x2" timber joists for 1st floor with no load bearing wall above it only a 3" breeze block wall about 3ft away parallel to it.
The span of the opening will be 2.30m wide
I am preparing drawings myself (engineering draughtsman in former life) to apply for Building Regs approval . Can I do calculations my self ?
Will single brick wall be wide enough to support steel beam and what length of bearing will be necessary ? Building piers would be a problem due to proximity of services and kitchen cabinet layout.
Any help or comments would be appreciated
