Calling all panel builders
We build a few motor control pannels at work.
What are you after? ;)
I'm after someone to make me some terminated lengths of tri-rated cables for use in a CU I'm building....
Not for free, BTW.
I know they sell tri-rated and BS 6231 by the reel - I'll have a rummage to see if they do short pre-terminated lengths....
Well I was thinking 25mm², in case I ever ended up with a 100A supply. The only thing that puzzles me is that I'm pretty sure that the cables you get in normal CUs with 100A incomers are only 16mm², but I can't see how they can carry 100A at 70°.
Happy to be proven wrong and go for 16mm² though.
Brown & blue, or red & black - I'm not bothered
For the sake of discussion let's assume the tri-rated cable has a full load operating temperature of 90° C.
My copies of the BS EN 60439-1 and BS EN 60439-3 are probably out of date but the principles are unlikely to have changed much.
Distribution Boards for use by unskilled persons have a temperature rise limit of 70° C on outgoing terminals. The temperature limit on busbars and conductors which are part of the DB is limited by, for example:
permissible temperature limit of insulation.
However, it does say that it can also be limited by: permissible temperature limit of the insulating materials in contact with the conductor.
So this appears to mean that a 16mm² cable running at 90° C would be ok provided that no cables rated at a lower temperature are allowed to touch it :eek:
I wonder what the DB installation instructions say :D
Tri-rated is actually OK up to 105°, but the principle is the same..
A tad tricky to guarantee within the confines of a CU/DB...
I'll let you know when I've written them. :LOL: Any suggestions?
My only suggestion would be to use 25 mm² cable for the internal connections - but it would appear that you have already decided to do that :D.
