Hi i thought you would be the guy for the best answer!
I closed in my under stairs last year with a 3x2 frame clad in 18mm mdf. There is a door cut into this which is flush with the face of the mdf but has 18mm thick skirting along the bottom. When i construced this i used normal butt hinges on the door but i dont like the look and also the skirting has to be cut back from the edge of the door by 18mm so it can open without fouling on the skirting.
I want to redo this as i want to make the opening bigger but want to lose the butt hinges for a cleaner look. are there any hinges that will throw back 36mm??
I hope that makes sense!
Any help would be great.
lee
lee
