Camping at Aldi
40 quid?! It's basically an extension lead! You'd be better off making up your own extension lead with an inline RCD.
'Camping' is broadly used nowadays; is this for a tent or a caravan?
The picture on Aldi's website reminds me of "the apprentice", where they were being given advice on advertising "selling the dream not the product".
Clearly someone has taken this a long way and they are selling the dream of drying your hair in a caravan. :rolleyes:
HI
I was going to get two RCD sockets and put them in a waterpoof box till i saw this unit.
and it's for a tent.
Caravans have plug sockets bulit in why need this unit in there as well???
I havn't got it yet due to the rain and the wind :cry:
Jake
TBH its not that bad, it might cost you nearly that for all the bits to make your own.
they are not that bad, better than a cheap reel with a 16A ceeform on the end.
IP44 rated, designed for a tent, not a caravan, RCD and 10A MCB protecting sockets.
not sure why the pic shows it in a caravan though???
I wonder if it complies with 721.55.2.6? I have seen many with smaller than the 2.5mm cable.
Now they are 25 m (±2 m) in length getting cables long enough is a problem with the boat being 18 meters long in first place if wrong way around it leaves just 7m (±2 m) to play with. So now have to make up our own.
I do think SY cable would be better but now it says HOSRN-F (BS 7919) or
equivalent we don't have the option.
I note non of the adverts seem to give cable size or type. Colour yes how can one use yellow for 230v?
The cable needs to be harmonized, 05 = 300v/500v, R = Rubber (Natural or Synthetic) conductor insulation, N = Polychloroprene Rubber jacket, F = Fine wire flexible cable. //www.diynot.com/wiki/electrics:harcode
It is quite easy to use yellow for 230v if it is rated for 300v/500v, it is just site convention which makes us think yellow cable is only for 110v cables.
You know those Aldi special buys are on a 3 month rotation? How many times over the past years have I coveted the cordless fondue set.. Ahh
Apologies if I have pi$$ed anybody off.
I posted in a fred wot I should not 'ave.
I have done the same myself it was only when link did not work I looked at the date.
I have noted over the years Aldi and Lidi produces do change. The both do car radios at around £50 and each time something normally small has changed.
