hello I have a camray 5 oil burner,,,and its just started doing this,,,it fires up heats the rads till they hot then stops,,,then when they cool right down it starts heating them again and so on,,,same with the hot water,,,it fires up on morning and heats the water till its red hot,,,then a few hours later when the water has cooled and its only warmish the boiler wont fire again to heat it back up to hot,,,once the water has gone cold it will fire up again no problem and heat the water till its red hot again,,,its as if some kind of temperature sensor is faulty???,,,ive just had a new circulating pump fitted a few weeks ago if that means anything???
