Camray Boiler
23 Oct 2021
Hi All
I hope you can help
I have a Camray boiler that has just started running when it should be stopped.
I cannot work out why it was working fine, until now.
Any Ideas as to what the problem is.
I do not know which Camray it is. None of the numbers can be read.
It is probably about1985 model
Any motorised valves? Is the programmer set to off?
One for hot water one for heating. The programmer and room stat all set to off
Fine thanks
All fixed thanks for all your help.
Boiler works as should do now part fitted
