I have a camray 3 boulter oil fired boiler that is used to run central heating only. I currently have an issue whereby;
1) room stat calls for heat
2) boiler and pump both fire and start to run
3) both boiler and pump run for approx 4 mins then shut down, stat stops calling heat ( light goes out on room stat)
4) after a period of approx 4mins shutdown the whole cycle from point 1 starts again( boiler subsequently firing over and over again in a short space of time).
This is causing the rooms to take along time to get to desired temperature ( if they ever do at all) and to me suggests something is going wrong along the way.
I have already replaced both the pump (grundfos selectric) and the room stat. Would I be correct in thinking this could be an issue with either the boiler stat, heat exchanger or build up of sludge in the system contributing to a poor flow around the system??
Any help would be greatly appreciated,many thanks in advance...
Liam
Liam
