Camrey 5 hot water system
I assume that you are describing a Camray 5 combination boiler, and the heat exchanger is the domestic water heat exchanger. This will have 4 connections, 2 22mm primary pipes which are the flow and return to the boiler, and 2 15mm pipes which are the cold water supply and the hot water 'delivery' pipe.
It is usual to find the filling loop supplied from a 't' on the cold water supply.
Thanks, quite right, I had the two round the wrong way and have swapped the pipes this morning and all is well
Cheers
The DHW will work the other way round to a small extent but just not so well!
The water flows in opposite directions in the primary and secondary sides.
Tony
