Can’t access 1111 eng code pyronix enforcer
11 Oct 2020
Cant access engineer code 1111 as as far as I know I need to eliminate flashing yellow triangle and active fault and displays service required although alarm works ok cannot get rid of triangle
Tried various options without any success any help would be appreciated
Many thanks
Dave
Do you manage your own panel or was it supplier installed? If the latter the code won’t have been left as 1111
I can gain access to my managers code only via my my unset and set code not my engineers code
unless I could find out what code he entered is there a way I could do that
Dave
If you don’t have the engineers code you’d be better contacting the engineer. They’ve setup service intervals hence the triangle you are getting. There’s no issue ignoring the triangle but appreciate it will be annoying to see all the time!
Is there anyway to remove this as tried 1111 but doesn’t work he must have changed engineers code as well
But without the engineers code Dave, or defaulting the panel which I wouldn’t recommend
I have a Pyronix Enforcer demo kit if you want me to test defaulting the engineer code to see if it resets the zones or not let me know
Even if it does reset the zones it’s pretty simple to reprogram them
Decided to have a complete new alarm system as this 1111 problem is the end of a very long list of problems associated with this alarm and one that is wired rather than wifi but thankyou for your reply
