I'm fitting new bathroom suite & have found an existing solvent welded joint in an imperial 4 inch pipe is leaking. Having read some of the posts, it is clear that cutting out the offending joint is the best solution. Can I use a 110mm pushfit coupling to connect new metric pipe? I'm worried about leaks if using a combination of imp/metric parts. Access to this pipe is quite straight forward.
//media.diynot.com/32000_31022_13436_30174548_thumb.jpg[/img]
