Hi All,
Can someone advise me on box sash window manufacture?
I need to get some windows made
The window opening is approx 1.8m x 1.1m and the planning permission is for two sash windows side by side.
My problem is that if I get four normal windows made the boxes will be either side - that means two in the middle plus a separating vertical member. The central build up would amount to 250-300mm. I would like to reduce this central area by having the weights for each sash running on the outside of each window. I know I can ring around window manufacturers but I would like to know my options before doing that because I often find suppliers shape their advise to get the work!
I attach drawing...
Many thanks
View media item 48926
I attach drawing...
Many thanks
