My elderly in-laws had an RCD tripping issue last week and it took two visits by a very expensive electrician and 5 hours work to identify two wall sockets in the utility room had been scorched and were causing the RCD to trip. It would appear that many years ago, a kitchen installer extended an existing socket to two others and used aluminium cable. One of the additional sockets is used for both the washing machine and dryer, which are regularly used at the same time, so it has been suggested that the load on that circuit is what is causing the problem.
Both sockets were replaced and the cable wires cleaned up and the RCD tripping appears to have been resolved. We have been warned to only use the washing machine and the dryer, one at a time to reduce the load and avoid the same thing happening again.
I am wondering if it would be possible to introduce an additional circuit into the CU, specifically for use by only the washing machine and dryer, thereby avoiding using the existing two sockets that have been installed using aluminium cable.
Here's a photo of the CU:
View media item 108820
As you can see, there isn't currently any space for a new MCB, but I did wonder if the existing double pole RCD could be replaced with one that doesn't take up two slots, allowing an additional MCB to be installed along side it? The photo isn't that clear, so to confirm, the RCD is at the far left of the CU. If this is possible, would it also be advisable to use a thicker cable? I guess the next size up would be 4mm, which seems like overkill.
