I'm wiring up a temporary lighting + spur setup in my garage - no fixed wiring to the garage so the whole system will be plugged in only when needed.
I plan a single spur for a couple of sockets, and a single lighting circuit. I am getting a unit like this so I can turn the whole garage off:
http://www.screwfix.com/p/13a-switched-fused-connection-unit-neon-flex-outlet-metal-clad/40906
Will this unit allow be to connect multiple cables or is it a one-cable-in, one-cable-out fitting? In which case, do I need two - one for mains and one for lighting?
I suppose I'm really asking if I can use this unit as a junction box, or need a junction box and then two switches? I choose switched units so I can be damn sure everything is turned off
