can a waste pipe be connected after a U bend?
10 Dec 2007
London
Hello all!
To drain the water from the WM,
I have connected a self cutting waste pipe to the drain under the bath.
I noticed the overflow from the bath is connected before the u bend.
it just occurred to me that I have connected the self cutting waste pipe after the u bend.
will that cause problems?
thanks!
Apart from the fact it breaches building regs. it will probably smell :eek: & if you drain the bath while the washing m/c is running you may suck all the water out of it! :(
yeah i thought i had probably messed that up!
fairly disastrous : (
better fix that then,
thanks!
