Can anyone help!!! boiler pressure drop
27 Oct 2009
Manchester
Hi, I have just moved into a house with an old boiler its a Vaillant VCWGB 240h. but cannot afford to replace it at the mo. I was wondering if anyone knows how to adjust the pressure as it seems quite low???? I am rubbish at this sort of stuff so please could it be explained in laymens terms. Thank you
Thanks for that, only the underside of my boiler has about 6/7 more pipes running in and around it, is this filling tap obvious???
the silver braided pipe may not be connected
the inlet valve is on the cold in
the outlet valve for the filling loop is usually on the heating return :idea:
can you post a pic :?:
