can anyone help please ?
26 Sep 2005
i have just purchased an xpelair fan for the bathroom. the wiring for the fan itself is straight forward blue/brown/ andearth. but the electrician who did our wiring left a cable sticking out the wall to connect to the fan. its the wires on the cable that i dont get. there is one black wire,one grey wire,one copper wire which is earth i presume,and one black wire. total of 4 wires in the cable. can someone tellme what goes where please ?
Usually you have a permanent live to the fan, a switched live from your light switch and neutral.
The idea is that after you have switched your light off the fan will kepp running on a timer so needs a permanent live.
Not sure on the colours you have mentioned though, I would guess at one of the bacls being a switch wire, the other a neutral and the grey a permanent phase, BUT I would presonally test them using a meter to find out what is what.
Sure it's not Black, Grey and Brown?....
http://www.iee.org/Publish/WireRegs/Cable Colours Leaflet.pdf
