We've got this bathroom fan in a flat we've moved into. It powers on when the light switch is turned on, and turns off approx. 5 mins after the light switch is turned off.
It's broken - the fan often stops turning when it's on (although operates fine in the 5 min period when you switch it off!) - and cleaning all the gunk out hasn't helped, so I'd like to replace it with an identical model, or something that hopefully won't require any redrilling or changing the power supply/wiring setup.
I've Googled the large product code on the sticker but came up with nothing. Any suggestions to identify it or advice on what would be the most simple thing to replace it with?
Many thanks,
Tom
