Can anyone reccomend a blade to cut laminate floor please?
14 Jun 2009
Kent
Evening.
Please can anyone reccomend a type of blade I need for my sliding mitre saw to cut laminate flooring. I currently have a 210mm 24tct blade which is great for slicing through battens but probably will only chew up my floor!
Thanks!
Some advice Here
Don't try and cut profiles around door frames etc. Cut under them.
Laminate flooring knackers tct blades(expensive) pretty quickly. Use a jigsaw with the flooring face down to prevent it chipping.
Thanks for your advice guys. I have a week off work next week so I have a week to get the job done to the wifes standard which is pretty high!
