can anyone recommend a 2 camera cctv WIRELESS system ?
You know wireless will require a power connection.
IP or POC cameras use just one cable, if you want bullets then 4K color vu is available in IP, if you want turrets then 4K color vu is available in poc. POC wont be as good but they are cheapa and with good cable are relatively easy to terminate.
the poc is limited 12fps recording I believe at 4K resolution.
Arlo or Eufy, I have Eufy and its brilliant. It has configurable recognition so you can get it to recognize humans/cats/whatever your choice and they are really easy to set up. You also only get clips of when something has been detected so you won't have hours of footage. Alerts on your phone, remotely view-able on your phone, I have found it to be excellent. Also the batteries are not quite half way flat (after 4 months) and it is on a high security level and it will be easy to charge as it is just a micro USB. I'd certainly think about checking the reviews on Youtube
