I bought the house with gravity system for both hot water and central heating (two water tanks in loft). I then have am unvented cylinder installed in the hope of better pressure. It was unfortunately marginally better so I' m thinking of adding a Grundfos scala 2 pump at the water main entry point. I still have the old boiler ( 20yrs+) and heating loop is vented, not sure if I can add the pump for added pressure with the existing system or I have to change the boiler and have the whole system unvented at the same time?
I'm looking to have good pressure when only one shower is in use but useable pressure when two in use, and will be adding a water softener so I'm thinking of the Scala 2 for the power required.
