I would suggest you contact B Control direct as you are installing a shower, whilst it is still an exempt building, some LA's take the (wrong) view it is not because of the shower.
This used to put me in the position of asking for an app for such work and when asked why, I then had to justify something I knew to be wrong.
To check their interpretation, some authorities take the view (wrongly) that as the building has a shower installed it is not exempt, so you need to check if that is the case.Why would you contact BC at all for something that the regs show is exempt? Unless BC are already involved why bother to raise the issue in the first place?
