Can I butt floor tiles?
10 Feb 2007
Kent
Is there any reason why I can't butt floor tiles together?
I am about to tile my kitchen floor and have dry laid some tiles and I prefer the look without a grout line ie laying the tiles butted next to each other.
Are there any issues/problems with doing this?
Many Thanks
Is there any reason why you would want to?
Tip: consider how much you'll like the look of the grime that will find itself into the gaps, 'cos it will.
Other than grime, grease, dirt, germs, more germs, more grime, animal hairs, insects, moisture trap, bacterial growth, smell, and more grime, no - you're on a home run. :D
1)The main problem will be expansion/contraction of your tiles, which could chips or even cause tiles to lift.
2) Unless you are very lucky the tiles will start to run out of line with each other, and as you have no grout, you will have no adjustment to realign.
3) Your joints will eventually fill with dirt/spillages, giving you a very fine black grout line..... :eek:
What trazor said about the tiles not lining up perfectly is correct - you only need the tiles to be slightly out and it'll look terrible.
You really need to grout tiles for the reasons already mentioned. If you grout butt laid tiles, the grout won't get deep enough into the gap and will come out easily.
Take our advice and give em a bit of space.
