Hi there , i was wondering if i could use my existing sky installation to add a freesat tv? Would i have to re-align the dish to another satelite? What satelite does sky tv use?
sky and freesat use the same sattelite position so dish realignment is not required
Be aware that satellite feeds cannot simply be split so if you want to add a receiver rather than replacing one you will need to run a new cable all the way back to the dish and you may need to repalce the LNB on the dish with one that has more outputs.
Or buy a receiver that does. Or a splitter. Or ignore the spelling of sattellite?
How do you suggest a receiver make the LNB operate in both horizontal and vertical polarisation at the same time?
I don't understand your comment? h/v at the same time? not without a twin receiver? I don't understand what you are talking about?
Is it not obvious to you that a splitter won't work because satellite (correct spelling BTW ) is different to an aerial signal in the was the reception works?Or a splitter.
What he means is that a Quad LNB is four satellite signal receiving devices (LNBs) in one housing. One output per cable. There's no splitting involved. The fact that you see a single block on the end of the dish stalk is irrelevant. What's inside is like having four single output LNBs, but it's combined in to one housing.
Satellite receivers with twin inputs have two tuners - one per input. Each input is fed by a direct connection to one LNB feed. Remembering what was said above, this could be two single LNB outputs from two separate dishes or two outputs from a Quad LNB which is obviously more practical in a domestic installation because of space.
Do you get it now?
Do you get it now?
No. So a block of flats have one satellite dish, but 20 people get a signal from that one dish. You state that there is no type of splitter device used. So where do I buy this wonder LNB device from? If as you state, that splitters are not involved?
Ah a multiswitch has been mentioned by the last poster. Is multiswitch not another term for a splitter?
