Hello - first time user here needing some basic advice. I've just replaced the flow / return pipes in the house we've just moved into and run new feeds to each rad (the previous system was a nightmare - flows and returns on the wrong way - radiators connected off of each other etc etc).
It's a much better job now, but I'm stuck on two points.
1) Rather than run the F/R to a "final" radiator - I've simply looped the F/R via right angles at the end of the line. Is this correct or should they be simply terminated with stop ends. The reason for doing this was to allow a little bit for future additions.
2) I've run two F/R feeds into unused rooms to add rads at a later date, and I've looped them again. Same question - should these be terminated individually rather than looped?
Simple questions - I just have no idea. I can't see what harm looping them will do as essentially a radiator forms a loop. But a friend told me that looping acts as a "water short circuit" and could cause uneven performance in the rest of the system as a radiator acts a resistor!
Any comments welcome (even the ones taking the...!!).
Cheers.
Cheers.
